MRT PTX Direct Powered Transponder
OdgovorNapisal/-a nitro-s » 02.01.2008, 23:20
MRT PTX Direct Powered Transponder. :wink:
Končno lahko kupimo še od drugih proizvajalcev in ne samo od AMB (monopolist). 8) :)
Specifications:
Stored numbers: 10, or 20 (with custom cloned options)
Case size: 20 x 15 x 12mm, waterproof and fuelproof
Weight: approx 5g (without power lead)
Mounting: direct fitting or optional 'tab' base (3 hole)
Temperature range: 0-50 C
Power feed: from a free RX channel (or 'Batt')
Power lead: approx 195mm or custom (replaceable lead)
Connection plug: standard servo plug
Operating voltage: 2.8V - 30V DC
Power consumption: approx 7.5mA @ 6V DC
Display LED: red or custom (blue, white, amber, green)
INFO: :arrow: http://www.rclaps.com/
INFO: :arrow: http://www.team-mrt.com/
Cena 45 (34) £ :lol:
Naročilnica: :arrow: http://www.team-mrt.com/pdf/rclaps/ptx_form.pdf
Še tuja mnenja: :arrow: http://www.rctech.net/forum/showthread.php?t=117075 (21 strani)
Zadnjič spremenil nitro-s, dne 03.01.2008, 00:09, skupaj popravljeno 3 krat.
OdgovorNapisal/-a AndrejG » 02.01.2008, 23:28
Pa se da ta transponder uporabiti pri nas na tekmah? Saj moram tudi jaz letos kupiti to zadevo za na tekme!
LP, Andrej
AndrejG
Pridružen: 06.06.2003, 12:52
OdgovorNapisal/-a DMX » 02.01.2008, 23:34
dela, dela.
OdgovorNapisal/-a AndrejG » 02.01.2008, 23:39
Pravijo, da res dela. Vendar sem zasledil, da ti naredijo le ''klon'' originalnega transponderja. Torej, če si svojega uničil, ti številke iz starega prenesejo v tega novega! :?
LP, Andrej
AndrejG
OdgovorNapisal/-a asso » 02.01.2008, 23:43
Ni ravno tak. Samo v določenih primerih. Pa še to mi ni jasno, če je stvar sploh legalna.
If you need a replacement or spare personal transponders the new i-PT has advantages over existing PT's. The i-PT is a 'cloned' version on your current ID number. If you have a damaged or broken AMB personal (broken lead etc) an i-PT replacement is now an option.
Jon, the PT number can't just be copied to clone a PT, ID# 1234567 is not the same as its output number. Unfortunately we can't program before we ship without having your existing PT, that's how it has to be.
jerry
asso
Prispevkov: 229
Pridružen: 20.11.2002, 19:11
OdgovorNapisal/-a Stocker » 03.01.2008, 00:10
Sam si lastim ta transponder lahk rečem da zadeva zaenkrat dela 100%.Maš več možnosti transponderjev,-kot klon svojga amb-ja+10številk
-normaln brez klona kje maš na izbiro 10 različnih številk če daš še kak funt več pa dobiš 20 številk.Tist ko še nima osebnega je tole res najcenejša varijata!
lp Gregor
Stocker
Prispevkov: 254
Pridružen: 09.01.2003, 01:01
OdgovorNapisal/-a Cimer » 03.01.2008, 11:22
Tudi sam imam ta transponder, vendar ste v tej debati pozabili povedati, da imajo vsi ti transponderji 10 enakih številk, kar pomeni, da se bosta prej ali slej našla dva tekmovalca z isto številko transponderja v isti kategoriji.
Nisem pa preverjal kako je to narejeno v programih za merjenje časa, ali sploh omogočajo, da imata dva tekmovalca isto številko transponderja, čeprav sta v dveh različnih kategorijah.
Lep modelarski pozdrav!
Marko S.
Cimer
Prispevkov: 99
Pridružen: 11.11.2002, 13:20
Re: MRT PTX Direct Powered Transponder
OdgovorNapisal/-a fr3nky » 18.10.2009, 22:45
vem da se bo tole slišalo malo neumno ampak zakaj so sploh tile transponderji?
fr3nky
Prispevkov: 6
Pridružen: 18.10.2009, 21:49
Kraj: brunšvik-mb
OdgovorNapisal/-a GHOST » 19.10.2009, 07:29
fr3nky napisal/-a:vem da se bo tole slišalo malo neumno ampak zakaj so sploh tile transponderji?
Za merjenje časa na dirkah.
OdgovorNapisal/-a fr3nky » 19.10.2009, 20:26
GHOST napisal/-a:
ok hvala za pojasnilo :))
fr3nky
Prispevkov: 6
Kraj: brunšvik-mb
