REDS 1/8 elektro
REDS 1/8 elektro
OdgovorNapisal/-a urko1988 » 06.11.2014, 08:44
After releasing the VX 1/10 scale electric motors REDS Racing now introduce their Brushless Motors for 1/8 scale.
Over a year’s worth of development has gone into the V8 1/8 line to make it a smooth, durable power plant for drivers and enthusiasts around the world. REDS Racing main goal is to offer high quality products as they do in Nitro category. The new line was developed together with REDS Team drivers to guarantee the highest performance and latest technology.
REDS 1/8th off-road motors are specifically designed to provide exceptional power, superior smoothness and control in combination with an extremely high efficiency and low temperature operation.
Coming with a highly finned CNC-machined aluminium can, V8 motor works at very low temperature in every conditions ensuring exceptional reliability.
Capable of both sensored and sensorless operation, the new line is ideal for all high speed buggy and truggy applications.
The motors are available in 2 KV options: 1900KV and 2100KV.
Motor main features:
CNC-machined 6061 T6 Billet aluminium ribbed heatsink can
High-strength balanced 4-Pole Neodymium sintered rotor
Low Resistance, High Power, Silver-plated Solder Tabs
High Purity Copper Windings
High RPM precision ball bearing for maximum performance and life cycle
Sensored and sensorless operation
Dual-plug sensor wire harness
Tech Spec:
Maximum input voltage: 22.2V 6S LiPo
Diameter: 42mm
Length: 69mm
Shaft Diameter: 5mm
Shaft Length: 18mm
Weight: 320g
urko1988
Prispevkov: 211
Pridružen: 14.06.2009, 08:53
Kraj: Benedikt
