Watt-meter?
Watt-meter?
OdgovorNapisal/-a nitro-s » 28.12.2004, 18:39
Zelo uporabna naprava. :lol:
Slika Slika
Measures energy (Wh), charge (Ah), power (W), current (A) and voltage (V)
Connector to use a receiver battery for measurement down to 0 V
Captures current peaks and voltage minimums(droops)
Accurate & precise - 0.01 A current and 0.01 V voltage resolutions
Rugged - handles 50 A continuous and 100 A peak at 60 V
14 ga., 7 x 37 stranded, high temp silicone rubber insulated wire without connectors
Small & Light: 2.8" long x 1.7" wide x 0.83" thick (70 mm x 44 mm x 21 mm), 2.5 oz.
Specifications:
Voltage 0-60 V, resolution 0.01 V. That's a 14 cell series li-poly pack!
Current 0-100 A peak, 50 A continuous, resolution 0.01 A
Charge 0-65 Ah, resolution 0.001 Ah. That's ~32 Amps for two hours!
Power 0-6500 W, resolution 0.1 W. That's ~8.7 Horsepower!
Energy 0-6500 Wh, resolution 0.1 Wh. That's lifting a 50 pound model into outer space (65 mi.)!
Operates from 4.0-60 V, 0 V with optional receiver battery pack
16 x 2 STN LCD display
Powerful, 8 MIPS micro-controller
Watt meter
OdgovorNapisal/-a romi007 » 30.12.2004, 00:58
Se strinjam, da je zelo uporabna naprava, samo kako jo dobiti v
Slovenijo?
Ali si že kaj poizkušal?
Roman.
romi007
Prispevkov: 1
Pridružen: 04.12.2004, 15:00
OdgovorNapisal/-a red_mamba » 31.12.2004, 15:04
to lahka sam narediš :wink:
mikrokontroler, LCD, pa malo programiranja.
Bad things happen to good people all the time for no reason!
Štrom: http://www.red-mamba.com
Prosti čas: http://www.maddogs-clan.org
red_mamba
Prispevkov: 47
Pridružen: 10.12.2002, 21:18
OdgovorNapisal/-a Robert » 31.12.2004, 17:26
Mamba-ti si stručnjak z micro-controlerji,lahko bi kaj spisal 8)
Saj veš P= U x I :D
Robert
Prispevkov: 171
Pridružen: 27.12.2002, 15:34
OdgovorNapisal/-a red_mamba » 31.12.2004, 18:56
sej ne da nebi hotu, sam cajta nimam nč :(
še miljon svojih projektov mam za dokončat :?
red_mamba
Prispevkov: 47
OdgovorNapisal/-a Čur » 31.12.2004, 20:57
red_mamba napisal/-a:to lahka sam narediš :wink:
Jaz pa mislim, da ne znaš!!!!
OdgovorNapisal/-a red_mamba » 31.12.2004, 22:06
LOL, u redu je sine, če ne verjameš prid h men pogledat, pa če me ne poznaš mi ne bučk lušit a prov? :lol:
lohk si pa 1. moje internet strani pogledaš da ne boš zastonj h men hodu :lol:
Zadnjič spremenil red_mamba, dne 31.12.2004, 22:12, skupaj popravljeno 1 krat.
red_mamba
Prispevkov: 47
OdgovorNapisal/-a red_mamba » 31.12.2004, 22:07
lohk pa tud poveš za kulk se greš stavit, tko da bo bolj zanimivo za druge
red_mamba
Prispevkov: 47
