Blu-ray
Blu-ray
OdgovorNapisal/-a TomyBoy » 07.02.2006, 22:16
Leto 2006 bo prelomno leto na tržišču medijev.
Na kratko...
" Blu-ray, also known as Blu-ray Disc (BD) is the name of a next-generation optical disc format jointly developed by the Blu-ray Disc Association (BDA), a group of the world's leading consumer electronics, personal computer and media manufacturers (including Apple, Dell, Hitachi, HP, JVC, LG, Mitsubishi, Panasonic, Pioneer, Philips, Samsung, Sharp, Sony, TDK and Thomson). The format was developed to enable recording, rewriting and playback of high-definition video (HD), as well as storing large amounts of data. A single-layer Blu-ray Disc can hold 25GB, which can be used to record over 2 hours of HDTV or more than 13 hours of standard-definition TV. There are also dual-layer versions of the discs that can hold 50GB. "
Predstavitev proizvajalcev na CES-u 2006.
http://www.cinenow.com/us/play-video-191.html
Blu-ray mediji velikosti od 20GB-50GB in celo 100GB. :)
http://www.blu-ray.com/media/
Blu-ray predvajalniki:
http://www.blu-ray.com/players/
Bolj zanimiva zadeva, Blu-ray enota za osebne računalnike.
http://www.blu-ray.com/drives/
Bitka se še le komaj začenja, saj na drugi strani forsira svoj HD-DVD format Toshiba. Na svojo stran so uspeli prodobiti:NEC, LG, Sanyo, ... Vendar so glavni favoriti Pioneer, Sony, Philips, etc, na strani Blu-ray tehnologije.
OdgovorNapisal/-a Ghostbuster » 07.02.2006, 23:54
Samo kaj pa ta blu-ray tehnologija, kak ma rešeno zapisovanje...?
Kakšna posebna tehnologija al kak?
Freestile wind riders !!!
SlikaSlika
Ghostbuster
Prispevkov: 77
Pridružen: 09.01.2005, 15:36
Kraj: Maribor - Rače
OdgovorNapisal/-a mihec87 » 07.02.2006, 23:57
Ja spet cisto drugacna tehnologija samo pri teh novih bo problem ta trusted computing no sj cas bo pokazal svoje..
mihec87
Prispevkov: 84
Pridružen: 13.12.2003, 17:52
OdgovorNapisal/-a XMach » 08.02.2006, 00:22
Ta tehnologija tako hitro beži naprej da da kmalu se še oblečt ne bomo znali brez nje!
Zame je bla že neka "revolucija v malem" ko so prišli DVD DL ven!
Ko vidiš take BL tehnologijo pa res sam da te kap!
Gregor
XMach
Prispevkov: 170
Pridružen: 01.02.2006, 16:32
Kraj: Koper
