Playstation 3 & XBOX 360
OdgovorNapisal/-a TomyBoy » 11.02.2005, 21:08
Trenutno najbolj pričakovan kos elektronike. Sedaj so objavljeni tudi nekatere, sape jemajoče podatke on novem CELL procesorju, ki ga skupaj razvijata Sony, IBM in Toshiba.
One of the most gossiped-about and eagerly awaited technologies of 2005 is a powerful microprocessor called Cell. Produced by a consortium of Sony, Toshiba and IBM, Cell will be the brains of the next-generation Sony PlayStation 3, due out in 2006. If its builders' advance hype is right, Cell promises a new era of graphics-rich computers, as well as TVsets and home theaters capable of processing and moving large volumes of high-definition content. "Cell will make possible a transformation in entertainment like that from novels to movies.
Essentially a supercomputer on a chip, the Cell microprocessor is expected to transform consumer electronics and digital entertainment.
Cell's breakthrough multi-core architecture and ultra high-speed communications capabilities deliver vastly improved, real-time response for entertainment and rich media applications, in many cases 10 times the performance of the latest PC processors.
A single Cell chip is expected to be capable of surpassing 250 billion floating point operations, or 250 gigaflops, per second, rivaling the best mid-1990s supercomputer. In flops, it is six times as fast as Nvidia's new graphics chip.
Kaj več v prihodnjih mesecih in upam, da bo zadeva že prikazan na največjem sejmu zabavne elektronike E3 Los Angeles v maju, kjer bom od brata lahko posredoval exlusivne slike, iz prve roke.
Zadnjič spremenil TomyBoy, dne 04.11.2005, 16:48, skupaj popravljeno 2 krat.
OdgovorNapisal/-a idol plemenit » 11.02.2005, 22:43
8) 8) 8) 8) 8)
SONY JE BIL ITAK ZMERI CAR IGRALNIH KONZOL!
sM MEL FUL ZGODI ENKO IN JE BLA 100X pred takratnjimi kompi! :shock: 8)
idol plemenit
Prispevkov: 172
Pridružen: 19.06.2004, 22:23
OdgovorNapisal/-a Domen Žvegler » 11.02.2005, 23:31
Če j bla pa kdaj katera koli konzola po tehnologiji ali bilo čem drugem pred PC-jem si jaz dam nekaj odrezat. Daj no internet lahko na konzolo komaj od decembra lani napeleš. Pa eno konzolo mi pokaži ko zalaufa Autocad. :lol:
Unlimited-RC Team
Domen Žvegler
Prispevkov: 148
Pridružen: 28.04.2004, 14:03
Kraj: Maribor - Ruše
OdgovorNapisal/-a TomyBoy » 12.02.2005, 01:32
Dejstvo je to nasledna evolucija procesorjev, ki ga bo pač na našo srečo, :) prvi deležen PS3.
Nekaj tehničnih podatkov
-Cell is a breakthrough architectural design -- featuring 8 Synergistic Processing Units (SPU) with Power-based core, with top clock speeds exceeding 4 GHz up to 5GHz (as measured during initial laboratory testing)
-Cell is OS neutral - supporting multiple operating systems simultaneously
-Cell is a multicore chip comprising 8 SPUs and a 64-bit Power processor core capable of massive floating point processing
-Special circuit techniques, rules for modularity and reuse, customized clocking
structures, and unique power and thermal management concepts were
applied to optimize the design
-Contains 8 SPUs each containing a 128 entry 128-bit register file and 256KB Local Store
-2.5MB of on Chip memory (512KB L2 and 8 * 256K
-234 million transistors
-Prototype die size of 221mm2
CELL is a Broadband Architecture
-Fabricated with 90nanometer (nm) SOI process technology
-128+ concurrent transactions to memory per processor
-itd,itd...
Cell so predstavili na ISSCCju (International Solid-State Circuits Conference), daleč naj-naj-najboljša prireditev za semiconductorje. Tu so Intel, IBM,.. predstavili svoje najbolj pričakovano novost. Zahtevajo, da imaš delujoč procesor in ne samo specifikacije na papirju.
OdgovorNapisal/-a idol plemenit » 12.02.2005, 11:20
Domen Žvegler napisal/-a:Če j bla pa kdaj katera koli konzola po tehnologiji ali bilo čem drugem pred PC-jem si jaz dam nekaj odrezat. Daj no internet lahko na konzolo komaj od decembra lani napeleš. Pa eno konzolo mi pokaži ko zalaufa Autocad. :lol:
AKHM, A VEŠ KDAJ SO BILE PS ENKE? :twisted: :roll:
ALI VEŠ, ČEMU SO NAMENJENE? :wink: :roll:
POGLEJ:
Ko je bil ps2 še čisto ov, nisi nikakor mogel primerjat igrice z ps2 z igrico za pc! :twisted: Pa še danes po tolikih letih, lahko igraš na njem san andreas 8) in druge igrice brez kakršnihkoli nadgradenj!
Pri pc ju pa moraš imeti kar dobro grafično kartico, se ti ne zdi?
Pa še pri pc ju bo šele enkrat v začetku poletja! :roll:
Lp Idol- pa brez zamere.
idol plemenit
Prispevkov: 172
OdgovorNapisal/-a TomyBoy » 12.02.2005, 12:56
Da se no bo slučajno tu vnela kakšno PC vs Konzole war. Kot prvo, bi sam rad videl, da bi bile vse igre na PC, saj je hardversko TRENUTNO nadmočen, vendar temu ni tako. Zakaj ? Ker je na trgu konzole ogromna masa uporabnikov in založniki raje izdajajo igre eksluzivno za posamezne konzole, ki jih v velikih primerih PC ne bo nikoli ugledal, žal je temu tako in tudi v prihodnosti se ne bo glede tega nič spremenilo.
Samo primer:
Halo 2 for XBOX sold 2.4 million units in the U.S. and Canada, reaching $125 million mark in 24 hours from its release. "Halo 2 has generated more money on day one than any of the biggest movies in box office history including Spider-Man 2, Harry Potter and the Prisoner of Azkaban and The Matrix Reloaded. In addition, Halo 2 surpassed this past weekend’s box office favorite, The Incredibles, which grossed $70.5 million (U.S.) in three days compared to the $125 million pulled through by Halo 2 in one day".
To so ogromne številke, ki jih ne more prekositi niti filmska industrija.
Če si pristaš iger je danes skoraj nuja poleg PC-ja , posedovati kakšno konzolo ali tri. :wink:
OdgovorNapisal/-a idol plemenit » 12.02.2005, 13:12
Vojne ne o, dokler sm kle! 8)
No panic man!
Mam poleg pc- ja še dve konzoli, sam sta starehjši- ps1pa še neki.
Še kkšno konzolo ali tri? :shock:
Veliko denarja! :cry:
Je pa fora v tem, da mam še zmeri raj comp, ker so igra za ps2 kr drage!
Za enko mam 15 original iger. Na zečetku so bile po 13k! :shock:
Zdej pa niso vredne pol tok. :( :wink:
Pa se vrnimo na temo!
Čestitke sonyju, za tak tehnološki napredek! 8)
O njem pa jaz lahko le sanjam, in si ga za tisti denar niti ne želim! :D
idol plemenit
Prispevkov: 172
OdgovorNapisal/-a TomyBoy » 12.02.2005, 17:29
Playstation 3, naj bi bil lansiran na Japonskem, konec leta. Tako, da bo evropski izid nekje 2006 spomlad, vsaj upam. Cena pa tudi ne bo mogla biti pretirana, če so danes vse konzole nekje 150 EUR :PS2, Game Cume, XBOX.
OffTopic
Kar se tiče originalov, tudi ti niso več tako dragi, odvisno kje kupiš. Brat je pred dobrim mesecem naročil iz Hong Konga, Resident Evil 4 za Game Cube. Cena, komplet z poštnino je bila 8.500 SIT. Ko smo zadevo prešpilal, jo je v enem dnevu prodal naprej za isti denar. Dobro, to je tudi posledica, ker igre še ni na evropskem trgu, ampak zadevo se vseeno da lepo prodati, pa če tudi zgubiš nekaj na ceni. O čipih ne bom govoril, vemo pa, da ima danes skoraj vsak lastnik, v PS2-ja in Xbox-u, zmontirano kontraverzno zadevo. :wink:
Še nakj offTopic.03.03.1005 izdi "zopet" najbolj pričakovanega špila :) GRAN TURISMO 4 (playstation 2). Več o tem, naslednji mesec.
OdgovorNapisal/-a idol plemenit » 13.02.2005, 13:01
Fino ste to zrihtal po pošti! 8) 8) 8)
Čestitke! :D
idol plemenit
Prispevkov: 172
OdgovorNapisal/-a TomyBoy » 13.02.2005, 14:59
No, sej nismo mi nič zrihtal. :wink:
Evropa ima žal ultra drage igre. Že v UK so igre nekje 10-20% cenejše, kot recimo drugot po evropi.
Najcenejši trg pa je seveda Ameriški in azijski. Samo, je omejitev pri naročilu, ker te za recimo dve igri, takoj udrapnejo za carino. Tako si omejen na en komad. :x
OdgovorNapisal/-a TomyBoy » 13.02.2005, 22:28
Malce za primerjavo.
Playstation I
Playstation 2
Playstation 3 ?
OdgovorNapisal/-a TomyBoy » 13.02.2005, 22:47
Oba XBOX 2 in Playstatin 3, naj bi uporabljala High Definition Digital Versatile Disk. Kaj to pomeni ?
Da bo prikaz slike podprt tudi za High Definiton TV-je. To pomeni, resolucijo 1980 x 1080.
:shock: Igre na tej resoluciji.... :shock:
Testni programi v HD formatu se že prikazujejo širom evrope. V Cosmos Graz sem imel prvič videti zadevo od blizu. Slika je takšna da slika DVD zgleda prav bedno. Uradno naj bil konec leta večina TV hiš kot so SKY, začele oddajati v tem formatu.
HD TV uporablja kar 7 biljonov barv ja ...7 BILJONOV. To so pa števlike.
Malo za pokušino...:)
http://www.pioneer.de/eur/download.jsp? ... attachment
(Slednji je bil z EISA nagrado, proglašen za tv leta 2004-2005)
Zadnjič spremenil TomyBoy, dne 13.02.2005, 23:52, skupaj popravljeno 1 krat.
OdgovorNapisal/-a slowy » 13.02.2005, 22:52
:shock: :shock: :shock: :shock:
Uauuuuuuuuuu!!!
Take it slooooooowwwwwww!!!!
slowy
Prispevkov: 20
Pridružen: 07.12.2004, 23:15
OdgovorNapisal/-a Kostko » 13.02.2005, 23:13
Taka grafika k je na slik za Plastation 2 je povsej vrjetnosti iz računalnika. No ne morm biti zanesljivi vir, ker konzole nimam doma, vendar sm zadnič igral NFSU2 na PS2 pa je bla zelo zelo zanič grafika. PS2 ma tako grafiko kot računalniške igrice iz leta 1998. Tisti ki igrate PS2 boste tole zanikal, to pa po vsej vrjetnosti za to ker niste nikoli igral kakšne sodobne igre za PC.
Res je mal off topic, sam želim povedat da konzole še dolgo časa za tako ceno ne bodo presegle grafike katere tedaj dosega recimo grafična kartica Radeon 9200 128MB ali več.
Naj vas tale komentar ne zanese preveč, saj so konzole še vedno dober "potratnik časa", ter vir zabave, in tudi malo slabša grafika nikomur ne škodi preveč. Tko kot pravjo "malo dnarja, malo muzike". Jaz sm pristaš računalnikov :>.
Kostko
Prispevkov: 29
Pridružen: 19.09.2004, 21:26
Kraj: Jesenice / Kranj
OdgovorNapisal/-a TomyBoy » 14.02.2005, 00:06
Niti ne mislim komentirat tvojega posta, ker vidim da nimaš.....
Kaj sploh komentiraš zadeve, če nimaš konzole ???
Fant moj zlati, pa kaj misliš da tisti, ki imajo konzole niso igrali nobene nove igre na PC-ju. Seveda, če je pa na trgu PC iger, totalna suša, beda o bede. Na mojem X800 (Upam da veš, katere "grafa" je to :) ) se prah nabira, že od Half Lifa 2.
No, za pokušino, ti dam "en filmček" iz GT4, ki pride čez tri tedne. Pa tole je na 5 let stari zadevi, ki se imenuje PS2. :roll: :roll:
http://media.gameinformer.com/downloads ... /gt4-2.mpg Tokyo 45.5 MB
http://media.gameinformer.com/downloads ... /gt4-3.mpg Grand Canyon 32.1 MB
http://media.gameinformer.com/downloads ... /gt4-4.mpg Grand Canyon Replay 27.8 MB
http://media.gameinformer.com/downloads ... /gt4-5.mpg New York 44.1 MB
http://media.gameinformer.com/downloads ... /gt4-6.mpg New York Replay 42.8 MB
http://media.gameinformer.com/downloads ... /gt4-7.mpg NSXxy 26.8 MB
http://media.gameinformer.com/downloads ... /gt4-8.mpg NSXxy Replay 26.3 MB
http://media.gameinformer.com/downloads ... /gt4-9.mpg Swiss Alps 38.4 MB
http://media.gameinformer.com/downloads ... gt4-10.mpg Swiss Alps Replay 38.7 MB
http://media.gameinformer.com/downloads ... gt4-11.mpg Laguna Seca 45.2 MB
V glavnem, tukaj je govora o Playstation 3 in zgleda tudi o HD, ki lepo paše zraven. :wink:
OdgovorNapisal/-a EagleA1 » 14.02.2005, 07:59
Da se jest powem svoje mnenje :D
Pomojem vsak zagovarja svoje, samo ce rabis kisto sam za spile je velik bols konzolo met, ker grafika tm je rees dobra. Spomnem se ze ene par let nazaj, ko smo igral GT2 pa je bla ce takrt tm grafikam za prste obliznt. Ce bi pa hotu na racunalniku dosezt tako ali vsaj podobno grafiko bi pa mogu imet res ornk kisto pa enga postenga radeona notr( 9200 128MB je zihr premal), de o ramu pa o procu sploh ne govorimo. Res pa je de sam osebno velik raj sedim za racunalnikam pa spilam spile kork pa na konzoli z joypadom u rok ker mi je streljacine, al pa bilo kere spile velik bols igrat za kisto s tipkovnico, misko ali joystickam. Sam to je pac moje osebno mnenje.
Edin ena stvar mi ni jasna se pri konzolah? Klele sm brav de kupujete spile sam original iz ne vem kje po ne vem kasni ceni... Kva pa prepeceni cd-ji? Zih se je na suprnovi dal kj dobit k je se obstajala?
Ziga
EagleA1
Prispevkov: 60
Pridružen: 18.06.2004, 10:48
OdgovorNapisal/-a idol plemenit » 14.02.2005, 15:25
Kostko: Je že tommyboy vse povedu! :roll:
EagleA1: Se strinjam, povem pa ti da je na konzolah lahko igralnost še boljša!
Zakaj? Pomisli, tišpkovnice so delane za tipkanje, upravljalci konzol pa izključno za igrice!
Pa boš rekel: Ampak Idol, saj lahko nastavim tipke! :D
Že res, a kje si videl okroglo (ali različnih oblik) ergonomsko oblikovano tipkovnico, ki je narejena tako, da se vse ujema z igro in le tem?
Pa še to- joisticki od sonyja pa so neizmerno trpežni! :shock: :shock:
Tukaj se jih skoraj neda opisati! Moj je star že ohoho, in je v jezi že nemalokrat pristal z šutom v steni in je bil tudi deležen nasilnega stiskanja in pritiskanja, padcev z omare...
In še vedno dela brez kakršnihkoli motenj ali škripanja!! :shock: :shock:
Jasno, da se ti zdi igranje s tipkovnico lažje, ker si jo pač navajen, ali pa ti bolje ustreza!
TOMYBOY:
A kej veš kakšne so/ bojo cene za un tanki ps1? :oops:
Lp Idol. 8)
idol plemenit
Prispevkov: 172
OdgovorNapisal/-a miskolin » 14.02.2005, 17:30
A racunalnicarji nimate svojega foruma? Takle te pa zjeza. :wink:
miskolin
Prispevkov: 227
Pridružen: 10.02.2004, 13:07
Kraj: Bled
OdgovorNapisal/-a idol plemenit » 14.02.2005, 17:42
miskolin napisal/-a:A racunalnicarji nimate svojega foruma? Takle te pa zjeza. :wink:
sam SE NIMAM ZA RACUNALNICARJA! :D
Pss: gfrafika za ps3= :shock: :shock: = bolj kot real! 8)
idol plemenit
Prispevkov: 172
OdgovorNapisal/-a ŠKALEC » 14.02.2005, 17:48
Popravil sem svoj post, da ne bo TomyBoy živel v zmoti, da podpiram MOD chip-e, čeprav ni konzolaša, ki ga ne bi imel.
PlayStation 2 USB kamera za še več užitkov z konzolo !!
Zadnjič spremenil ŠKALEC, dne 14.02.2005, 19:05, skupaj popravljeno 7 krat.
