XRAY T2'007
XRAY T2'007
OdgovorNapisal/-a JC Borcy » 21.09.2006, 00:24
Ponovno nov model 1:10 elektro pri XRAY-u.
Razlika med T2 in T2'007 je v nižjem sredinskem delu modela - torej nižje težišče.
New T2’007 Features:
• Build on the highly-successful T2 platform
• US foam-spec edition (#30 0007) and EU rubber-spec edition (#30 0008)
• Super easy to build, maintain, set up, and drive
• Less sensitive to changing track conditions
• World’s lowest top deck and bulkheads.
• Top deck lowered up to 4.5mm compared to T2!!
• Longer top deck design minimizes tweak and makes the car more stable
• New unique XRAY Quick-Saver™ - 5 different Ackermann positions can be set thanks to new adjustable servo saver
• New rear split bulkheads allow more rear flex, and improved rear traction
• World’s lowest ultra-lightweight bulkheads CNC-machined from Swiss 7075 T6 aluminum
• Horizontal motor mount allows the motor to sit lower.
• Improved drive shaft blades reduce wear rate
• New servo arms and pivot ball allow servo to be moved towards car centerline
• Aluminum self-locking wheel nuts
• Chassis cut-outs under ESC allows extra cooling
• Improved balance by moving the electronics towards the centerline
• New rear upper top deck with two different positions for alu top deck mounting
• Fully compatible with the T2 platform, all spare parts and option parts are direct fit
• EU and US conversion sets available shortly
več informacij na:
LINK do opisa modela
OdgovorNapisal/-a GODFATHER » 21.09.2006, 07:27
Dobrodošli v deželo X-ray!
Kjer modeli letijo iz tekočega traku in se letno menjajo modeli do 2-3x. Samo še čakamo lahko kdaj bodo ukinili dele za T2. Tako kot so to nardili za modele 04.
Lep avto, samo škoda ker v cca. 1 mesecu bodo na policah tudi cca. 5-7 opcijskih delov!
OdgovorNapisal/-a Čur » 21.09.2006, 08:00
TC4
Ti pa ne razumeš skrbi X-Raya in podobnih, ki v izjemni skrbi za dobro počutje modelarja in v kakem ponesreči postrani prišraufanem vijaku raje poimenujejo nov model, kot pa zamenjajo vijak.
Prodajte stare avte, ki so bili seveda do tega momenta najbpljši in si kupite zadnjo naj naj različico!
OdgovorNapisal/-a JC Borcy » 21.09.2006, 10:47
Dejan nisi si pogledal dobro:
OdgovorNapisal/-a GODFATHER » 21.09.2006, 10:59
Ti tudi ne:
Avta sta kompatibilna, s tem da je v 007 izvedbi veliko novih delov, ki so kompatibilni, samo jih v starih modelih ni!
http://www.teamxray.com/teamxray/produc ... 2a550b859b
Gre za isto zadevo kot jo X-ray izvaja že leta! Vsakič nov del, ki je boljši od starega. Čeprav je stari bil najbprej tako hvaljen, da boljšega ni moglo bit, potem pa dajo novega na trg in je ta sploh najboljši in sedaj boljšega ni, torej serejo po lastnih izdelkih.
Žal, je to velika slabost določenih proizvajalcev, še posebej X-raya. Pri AE tega ni. Še sreča! Je pa to dobro za tiste, ki morajo imeti najnovejše avte, ker se potem "stari" prodajajo ceneje.
T2'007
OdgovorNapisal/-a modridirkac » 21.09.2006, 11:59
V marsičem se strinjam z Dejan-om. In njegov TC4 je res še vedno vrhunska šasija, marate pa tudi vedeti da ga na zadnjih prvenstvenih dirkah v evropi enostavno ne najdemo več me prvih 10. Prevladujejo Xray, Hot Bodies, Yokomo in seveda Tamiya.
aja, še to zbiram prednaročila za XRAY T2'007, garantiram najboljšo ceno, in dobavo med prvimi!
Miha
ljubitelj dobrih in lepih vozil :)
spletna avtomodelarska trgovina in podpora RC Cars
http://www.bolha.com/trgovina/mihadeb/
miha@debevc.si
modridirkac
Prispevkov: 20
Pridružen: 19.09.2006, 16:54
OdgovorNapisal/-a DMX » 21.09.2006, 12:22
Drugo leto bodo v SLO DP sami X reji
X-WORLD !
LOL !
DP z Xray-i
OdgovorNapisal/-a modridirkac » 22.09.2006, 13:48
Ideja je seveda zanimiva in izvedljiva. V okviru svojega kroga avtomodelarskih zanesenjakov garantiram vsaj štiri tekmovalce na enaki Xray T2R osnovi, za katero menimo da je v tem trenutku najboljši kompromis med ceno, lastnostmi in kvaliteto in odlična osnova za začetek udejstvovan na dirkah.
miha@debevc.si
modridirkac
Prispevkov: 20
OdgovorNapisal/-a nitro-s » 22.09.2006, 23:39
Nekateri pač nenehno vlagajo v razvoj in v testiranje svojih modelov. 8)
Drugi pa spijo na stari slavi. :oops:
Saj veste, ni vse v novem modelu. :wink:
Xray T2'007 EU
OdgovorNapisal/-a modridirkac » 24.10.2006, 17:02
Zdravo,
obveščam da je omenjeni novi Xray T2'007 od četrtka 26.10. pri nas na zalogi. V kolikor vas zanima nakup pregled v živo,...
se mi javite na miha@debevc.si
miha@debevc.si
modridirkac
Prispevkov: 20
T2 007 Conversion Sets
OdgovorNapisal/-a nitro-s » 24.12.2006, 19:53
New T2 007 Conversion Sets
300941 T2 007 - US Foam-Spec Edition - Conversion Set
300942 T2 007 - EU Rubber-Spec Edition - Conversion Set
INFO: http://www.teamxray.com/teamxray/news/n ... 7a6cdd8d98
