NOVI zobniki Robitrinic za modele 1:18
OdgovorNapisal/-a nitro-s » 05.12.2006, 14:24
NOVI ALU in METAL zobniki Robitrinic za modele 1:18 za 2mm os motorja :wink:
RW1808 1/18 Pinion Steel 8T 48dp
RW1809 1/18 Pinion Steel 9T 48dp
RW1810 1/18 Pinion Steel 10T 48dp
RW1811 1/18 Pinion Steel 11T 48dp
RW1812 1/18 Pinion Steel 12T 48dp
RW1813 1/18 Pinion Steel 13T 48dp
RW1814 1/18 Pinion Aluminum 14T 48dp
RW1815 1/18 Pinion Aluminum 15T 48dp
RW1816 1/18 Pinion Aluminum 16T 48dp
RW1817 1/18 Pinion Aluminum 17T 48dp
RW1818 1/18 Pinion Aluminum 18T 48dp
RW1819 1/18 Pinion Aluminum 19T 48dp
RW1820 1/18 Pinion Aluminum 20T 48dp
RW1821 1/18 Pinion Aluminum 21T 48dp
RW1822 1/18 Pinion Aluminum 22T 48dp
RW1823 1/18 Pinion Aluminum 23T 48dp
RW1824 1/18 Pinion Aluminum 24T 48dp
