1/36 Micro-T Stadium Truck
OdgovorNapisal/-a JC Borcy » 29.01.2007, 10:05
* Fully independent suspension with friction dampers
* Differential-equipped transmission with adjustable slipper clutch
* Powerful, pre-installed micro motor
* Included Ni-MH battery pack with portable alkaline automatic peak charger
* Team Losi 27MHz radio system
* Electronic Speed Control with Reverse
* High-traction rubber tires on pre-mounted on durable nylon wheels
* Includes 8 AA heavy-duty batteries for transmitter
* Includes 8 AA alkaline batteries for charger
Product Specifications
Type: 2WD Stadium Truck RTR
Scale: 1/36
Length: 4.5 in (114mm)
Width: 3.5 in (89mm)
Wheelbase: 3 in (76mm)
Weight: 3.4 oz (96g)
Chassis: Composite tub
Suspension: Independent
Drive Train: 3-gear transmission w/gear diff and slipper
Tire Type: rubber multi-pin rear/ribbed front
Motor or Engine: Micro Electric
Speed Control: Electronic, Fully Proportional Forward/Reverse
Radio: 27MHZ AM Pistol
Servos: Sub-micro
Batteries: 4.8v, 150MAH NiMH (included)
Charger: Peak (included)
Wheel Size: 0.75 in (19mm) diameter
Kit/RTR: RTR
Shock Type: Coil-Over Friction Dampers
Body: Factory-decorated Stadium Truck
Ball Bearings: BB-Equipped Transmission
Needed to complete
Nothing.....everything's included!
http://www.teamlosi.com/Products/Defaul ... D=LOSB0230
OdgovorNapisal/-a MuddyFox » 30.01.2007, 16:55
Hoce li biti toga za kupiti u SLO?
Nebec mozda?
Eagles may soar, but weasels don't get sucked into jet engines!
MuddyFox
Prispevkov: 4
Pridružen: 03.01.2007, 15:25
Kraj: Zagreb (CRO)
OdgovorNapisal/-a Janja » 23.04.2007, 12:22
Imeli ga bomo v Logatcu!
Janja
Prispevkov: 44
Pridružen: 05.03.2003, 12:31
OdgovorNapisal/-a Janja » 10.05.2007, 12:32
Na zalogi :-)
Janja
Prispevkov: 44
