SERPENT 960 WOS steering block Pro set
OdgovorNapisal/-a ŠKALEC » 31.03.2007, 15:55
Lep pozdrav !
Serpent today released these WOS steering blocks set for the Serpent 960 that contains 2 steering blocks, bearing eccenters, ceramic bearings, spacers and nylon pivot ball nuts. Featuring a different offset to the standard kit versions, the blocks can be used in 2 different configurations by swapping the side of the car they are mounted on. These changes, depending on the side the steering blocks are used on, will either give you more turn in on corner entry, or more on power steering at corner exit. The included eccenters ensure that the axle is raised higher than centre line, which enhances the effect caused by this new configuration.
VEČ TUKAJ: http://www.serpent.com/product/903234/
