Komanda Robbe - Futaba Megatech T3PM FM
OdgovorNapisal/-a nitro-s » 07.04.2004, 00:31
NOVA dobra komanda - pištola za ugodno ceno :shock: :lol:
New, high-performance pistol-grip computer system for RC car and racing boat operators.
High-quality computer system with accurate digital control of three channels and trims.
Modern case design with ergonomically positioned controls.
Switchable modulation in transmitter ´between:
1. FM (PPM) standard fast modulation (14 ms) and
2. HRS High Response System (4 ms), the new triple-speed modulation.
´Response time of servos and speed controllers reduced to 1/3 (can only be used with HRS receivers and digital servos).
Large 100-segment LCD screen displays system settings in clear form.
10 model data memories, with model name, model copy and model reset; simplifies management of different models.
4 digital rocker buttons and handle button for adjusting trims and mixer functions, even while the model is running.
ABS intermittent brake for optimum grip when braking through turns.
2nd Drive Condition; by pressing a button a second setting can be called up for the functions which are to be adjusted during a race.
´This allows the operator to adjust the car´s set-up lightning-fast.
Switchable functions:
Exponential function on all three channels
Dual Rate, steering
Braking point
Steering and throttle trim
ABS braking point
V-mixer rate
Brake mixer rate
Steering servo speed
Brake mixer from throttle / brake channel to channel 3; convenient method of setting up and operating front and rear brakes.
Free assignment of adjustors and rocker buttons.
Freely adjustable V-mixer for special mixer functions.
Integral charge socket for easy conversion to rechargeable batteries
The system is available in two versions: one with standard FM receiver, the other including an HRS receiver.
Specification:
Dimensions: 210 x 180 x 90 mm
Weight: 605 g
Frequency band: 40.00
Channel spacing: 10 kHz
Spotfrequencies: 22.00
Current drain: ca. 250 mA
Power Suply: 9.6
Transmision system: FM/HRS-FM
Functions: 6/3 Servos
Cena: 149.90 E (sprejemnik R 133F) ali 169.90 E (sprejemnik R203 HF) (bruto)
Nova nižja cena za komando Futaba Megatech T3PK PCM samo: 369.00 E (bruto) 8)
INFO: http://shop24.derschweighofer.com/shop/fernsteuerungen_futaba.htm
OdgovorNapisal/-a TomyBoy » 07.04.2004, 17:10
Lol. Zdej so znižal, ko mam SANWO. Ziher so tebe čakal, da so se zadnje znebil, zdaj pa imajo novo ceno. :x
