Hudy ultimate pro
Hudy ultimate pro
OdgovorNapisal/-a tr » 10.08.2004, 08:35
....... No comment......
tr
Prispevkov: 235
Pridružen: 18.11.2002, 15:43
Kraj: Žalec
OdgovorNapisal/-a ELO » 10.08.2004, 09:26
hudo, a ne?
OdgovorNapisal/-a tr » 10.08.2004, 15:53
Kulk je kej cena to me bol zanima.Lp Travca
tr
Prispevkov: 235
Kraj: Žalec
OdgovorNapisal/-a grilnet » 14.08.2004, 23:11
VIdel v živo na EP. Cena bo približno med 320 in 350 EUR vsaj tako sem zedel od Juray Hudy-a. BO pa vse lepo lično spravljeno v lepem alu kovčku. Po besedah g. Hudy-a je to nekaj revolucionarnega in 100% profesionalno. Cena je seveda temu primerna.
OdgovorNapisal/-a grilnet » 19.08.2004, 13:42
Cena je 302 EUR! Dobi se pri serpent@siol.com
OdgovorNapisal/-a Čur » 24.08.2004, 22:37
Main features:
• backlash-free, wobble-free mounting
• fully ball-bearing equipped set-up stands (12 high-precision ball-bearings)
• ultra-smooth, ultra-precise movement and operation
• CNC-machined, hard coated high-grade aluminum set-up stands
• CNC-machined, tough acrylic plastic toe/steering plate
• precision engraving for instant, reliable readings
Having the best car setup is one of the most important factors in winning races. The Hudy Set-Up System is the best and most popular set-up tool in the RC world!
Precision-machined, hard-coated high-grade aluminum components allow very easy and accurate set-up of your RC touring car.
The entire system is very small, light, and well-designed for comfortable and fast transport, and “one screw assembly.” The engraved scales and markings are easy to read, and all parts move very freely due to precision ball-bearings.
All Hudy Set-Up Systems allow you to comfortably and easily measure and adjust camber & camber intake, caster, front & rear toe, and steering throw symmetry.
Details
Price: € 149.99
OdgovorNapisal/-a nitro-s » 24.08.2004, 23:01
Se da to dobiti in naročiti pri serpent@siol.com za 150 € ali samo pri The Border Online pri katerem smo že naročali. :wink:
INFO: http://shop.the-border.nl/customer/product.php?productid=20799&cat=346&page=1
Podobno kot Hudy, samo bolj poceni - 70 € :lol:
Slika Slika
INFO: http://shop.the-border.nl/customer/product.php?productid=17964&cat=355&page=2
OdgovorNapisal/-a grilnet » 16.09.2004, 11:50
Ja zdajle sem videl da obstajata dva seta tega hudy enden ki ga je objavil Nitro-S in pa komleten set. Tisti pa tudi pri borderju stane 325 EUR
HUDY ALL IN ONE SET-UP SYSTEEM 1/10 200MM
1082555
with case and tweak board
Precision-machined, hard-coated high...
Our price: € 324.99
Tako da sem spet dokazal da boarder shop ni nevem koliko cenejši če sploh je!!!!
OdgovorNapisal/-a GODFATHER » 16.09.2004, 12:26
