Team Magic G4 EVO Pro 1:10 TC
OdgovorNapisal/-a nitro-s » 31.08.2004, 18:45
Team Magic G4 EVO Pro 1:10 TC - NITRO
Cena: 300 € - cca 72.000 Sit
- 4mm Lightweight chassis k1475
- With the new Fuel tank k1419
- Carbon side plates k1439
- K-factory G4 alloy rail mount k1432t
- Carbon brake bracket k1438
- Carbon arm stiffener brace k1442
- Super hard universal joint set k1462
- Alloy sliding steering servo saver k1470b
- Hard-coated alum. threaded shock absorbers
- Lightweight M0.8 2-speed system (super efficient)
- Vented brake disc & brake cam bearing
- Soft belts & lightweight dust-free pulleys
- Lightweight pivot balls
- Light weight middle & 2-speed shaft
- Full high quality ball-bearings
- Low CG front & rear gear differentials
- Specially designed 5th body post
- Carbon Radio Plate
- Front one-way set
- 30mm push type clutch set
- Front adjustable anti-roll bar set (with alum. mounts)
- Rear adjustable anti-roll bar set (with alum. mounts)
Prodaja: http://shop.the-border.nl/customer/product.php?productid=16634&cat=403&page=1
Proizvajalec: http://www.teammagic.com.tw/products2.php?action=show&order2=1300&order=120&pid=505
OdgovorNapisal/-a nitro-s » 31.08.2004, 23:03
Na Evropskem prvenstvu 2004 (A) je Luca Piromalli (I) z tem modelom zasedel 6. mesto. :shock:
Kar dokazuje, da je to vrhunski model. :wink:
K1480 G4 New Steering System (w/ 8pcs bearings)
OdgovorNapisal/-a ELO » 01.09.2004, 06:48
kako se že v eni drugi temi govori....
da dober voznik je tudi s slabim avtom lahko dober!
če potegnemo vzporednice je potem lahko tudi njihov 1:8C zanimiv, sploh za uspešen začetek, a ne!
OdgovorNapisal/-a tejko11 » 01.09.2004, 11:07
Jaz sem ta avto že videl v resnici in ga držal v roki. avto ne zgleda nič manj kvaliteten kot serpent.
za tiste ki še ne veste, se je tak avto že peljal po prvi slovenski pisti(tolmin) :D
Lp Matej
tejko11
Prispevkov: 193
Pridružen: 03.01.2003, 20:49
Kraj: Sežana
