Associated 1:18 4WD Off Road
OdgovorNapisal/-a GODFATHER » 16.09.2004, 09:30
RC18T 4WD Ready-to-Run Truck
Team Associated is proud to announce the RC18T Ready-to-Run, their first
"mini" sized, 1:18 scale vehicle. The 18T is not your typical "toy-class"
small truck. it was designed from the ground up by Team Associated's
award-winning team of engineers for competition-level performance and
rugged durability far beyond the competition.
The 18T's racing heritage is apparent in many features of the truck,
including its efficient shaft-drive, 4WD powertrain featuring adjustable
ball differentials front and rear. The 18T is powered by an inline-mounted
"Super 280" high-performance motor, bolted to an aluminum motor mount with
several mounting holes to fit most any aftermarket 1:18 scale hop-up motor.
A high-capacity 1100mah nickel-metal hydride (Ni-MH) battery pack is
included with the 18T, as well as a convenient charger. The 18T comes
standard with a 55 tooth spur gear and a real metal 12 tooth pinion with
set screw. However, the truck will accommodate larger spur gears (up to 60
teeth) by changing the small gear cover on the underside of the chassis.
All the Team Associated "XP" series electronics in the 18T are completely
modular, allowing independent replacement of the receiver, steering servo,
and the new "XPS" micro speed control with reverse, which provides smooth
throttle control and will handle most aftermarket hop-up motors.
In the suspension department, the 18T distinguishes itself from the pack
with real oil-filled shocks for smooth, consistent damping. Each of the
four lower suspension arms are identical and interchangeable, front to back
and right to left. Molded upper suspension links ensure that the 18T's
suspension is correctly set from the start. However, steel or titanium
turnbuckle kits will be offered for those racers wanting more
adjustability. The 18T also features four high-traction "Mini-Pin" racing
compound tires with foam inserts mounted on racing-style dish wheels.
Of course, the 18T will be supported by a full line of Associated's
"Factory Team" performance parts and accessories, including machined
aluminum suspension arms, shock towers, and shock bodies. In addition,
Reedy will soon be offering more powerful motors and batteries to fit the
18T and other Mini-sized vehicles.
If you're looking for the next big thing in small trucks, you've found
it.Team Associated's RC18T!
Part number and retail pricing:
#20100, Team Associated RC18T 4WD Ready-to-Run Truck, $279.99
UPC# 78469520100
Availability:
November 2004
We site page:
http://www.rc10.com/shusting/CatalogHub ... kit18t.htm
http://www.teammagic.com.tw/phpBB2/viewtopic.php?t=524
OdgovorNapisal/-a šupak » 16.09.2004, 20:41
Ej ljudi, pa taj sploh ne zna slovenski.
šupak
Prispevkov: 80
Pridružen: 05.03.2003, 19:30
OdgovorNapisal/-a alesb » 17.09.2004, 07:39
šupak napisal/-a:Ej ljudi, pa taj sploh ne zna slovenski.
Tudi ti zgleda da ne. Pa niti hrvatski ali srbski ali bosanski :lol:
"joke"
alesb
Prispevkov: 135
Pridružen: 10.03.2003, 10:16
OdgovorNapisal/-a MaNe » 17.09.2004, 15:19
Človek je objavil novost in če koga zanima si bo prebral.
Za brezveze pa zihr nebo šel prevajat, ma premalo cajta.
