Diff Adjuster alu. Pro (S710)
OdgovorNapisal/-a JC Borcy » 15.06.2005, 00:26
Complete pro diff alu. adjuster set. Fits directly onto the Serpent 710 differential and comes complete with aluminum diff adjuster, shoe and adjuster screw.
#802393 - Description
Serpent is pleased to present this beautifully machined aluminium Pro diff adjuster. Suitable for use on the front and rear of your Serpent 710, this part fits directly onto the standard differential, this orange anodised part allows for more consistent diff adjustment due to its stiffer construction.
The truly innovative part of this new adjuster set however, is the use of a diff shoe. Made from a PTFE material this diff shoe creates a much improved and smoother differential movement due to the material used. Also when the part wears you only need to replace the shoe.
OdgovorNapisal/-a ŠKALEC » 22.06.2005, 10:56
Tudi ta barva ni od muh !
SE710-018 Aluminum Differential Adjustment Hub For Serpent 710 Weight: 10.00 g
SE710-005 Front OneWay Tuber For Serpent 710 Weight: 25.00 g
OdgovorNapisal/-a TEST-admin » 22.06.2005, 12:58
To je una tastara farba. 8)
Pa aluminij je za kur......, mehki je. :wink:
TEST-admin
Prispevkov: 4
Pridružen: 22.02.2003, 23:47
Kraj: Maribor -SLO
OdgovorNapisal/-a nitro-s » 22.06.2005, 20:56
Pa tudi novi širši (5mm) jarmen se vidi. :wink:
801256 Timingbelt 201X5mm rear Pro
