Opcijski deli za M18T
OdgovorNapisal/-a JC Borcy » 18.10.2005, 21:59
#388400 - Front Alu Oil Shock Absorbers (2)
Alu body oil-filled front shock absorbers for XRAY M18T provide ultra-smooth operation. Set of 2. Set of 2 front shocks come pre-assembled from factory without oil and springs. A "must have" for serious racers.
#388401 - Rear Alu Oil Shock Absorbers (2)
Alu body oil-filled rear shock absorbers for XRAY M18T provide ultra-smooth operation. Set of 2 rear shocks come pre-assembled from factory without oil and springs. A "must have" for serious racers.
#385301 - Alu Drive Shaft M18T - Set (2)
CNC-machined alu drive shafts replace stock composite units. Smooth operation and extra strength for use with high-performance motors. This set of two drive shafts comes completely assembled, ready to install in the car. A “must have” for serious drivers involved in high-competition racing.
#382095 - Alu Shock Tower Front M18T - 7075 T6 (4mm)
CNC-machined front shock tower for XRAY M18T Micro Truck is made from highest-grade 4mm-thick 7075 T6 Swiss aluminum. XRAY stylish black finish with trademark silver edging.
#383095 - Alu Shock Tower Rear M18T - 7075 T6 (4mm)
CNC-machined rear shock tower for XRAY M18T Micro Truck is made from highest-grade 4mm-thick 7075 T6 Swiss aluminum. XRAY stylish black finish with trademark silver edging.
#381171 - Graphite Micro Truck Conversion Set - Blue
Conversion set for XRAY M18 Micro Truck includes blue graphite chassis & top deck, alu motor stand for optional #382052 Alu Motor Holder M18T, alu collar for steering arm, composite antenna mount, battery backstops, optional battery strap post for 6-cell batteries, and all required hardware.
Also available in silver colour - #381172 - Graphite Micro Truck Conversion Set - Silver and in black colour - #381173 - Graphite Micro Truck Conversion Set - Black.
#382262 - Alu Suspension Block Right
CNC-machined suspension block made from highest-grade Swiss aluminum fits XRAY M18 and M18T. Front right steering block also fits rear left on M18 and on M18T fits front left and rear left. All hardware is included.
#382252 - Alu Suspension Block Left
CNC-machined suspension block made from highest-grade Swiss aluminum fits XRAY M18 and M18T. Front left steering block also fits rear right on M18 and on M18T fits front right and rear right. All hardware is included.
#382052 - Alu Motor Holder M18T - 7075 T6 (5mm)
CNC-machined motor holder for M18T made from high-strength aluminum with stylish XRAY black finish with silver edging. Strategically machined for optimum strength, durability, and lightness. Fits 300-size micro motors. Includes mounting hardware.
OdgovorNapisal/-a GODFATHER » 19.10.2005, 08:15
O tem smo govorili pred nekaj časa!
Asso Factory team 18T vam skoraj vse te stvari ponudi v ceni 170 eur. Tukaj pa moraš najprej kupiti za 110 eur avto potem pa še za ???? eur še dodatne dele! Kar pa je pomembno, da ne boste mislili, da so to vsi deli ki so jih izdali! Še veliko delov bo prišlo!
Lep nakup in prijetno varčevanje!
OdgovorNapisal/-a grilnet » 19.10.2005, 08:54
Tako je Dejan, kot smo vsi predvideli nas bo Xray zasul z dragimi opcijami, Asso pa skoraj vse to že ima.
