Komanda SANWA MX-3S SYNTHESIZER 40MHZ
OdgovorNapisal/-a nitro-s » 02.11.2005, 23:27
Komanda SANWA (Airtronics) MX-3S SYNTHESIZER 40MHZ
Frequency: FM 40MHz
System Features:
Unique and functional pistol grip transmitter design
Well balanced for precise control
Non-slip foam steering wheel
Well placed digital trim levers
Optimum thiord channel switch location
Big LCD display
Adjustable (70/30) Throttle trigger
Low nbattery warning
Quick access Sythnesized Setup
High performance mirco 3 channel receiver
High torque/ high speed SRM-102Z sservo
Receiver dry battery holder
Switch harness
NiCd charger jack in transmitter
Wrist strap holder (optional wrist strap)
Sound Beep (On/Off)
High Intensity Blue Power Light
Channel and Frequency Display
Screen Display
Digital Trim indicators (throttle and steering)
Battery Fuel Tank
Dual Rate Steering
EPA Steering, Throttlr, AUX
ARC Steering, Throttle
Model: Memory 18
Sub-Trim Steering, Throttle
Servo Rev Steering, Throttle, AUX
Battery: Voltage Display
Audio On/ Off
Synthesized Screen Display
Channel Number
Frequency Number MHz
RF Power Icon
Channel Select SetUp
Transmitter
Model: MX-3S
Output Power: 200 MW
Modulation: FM/PPM
Power Supply: 8 AA alkaline dry cells DC 12V or 8 cell NiCd Pack
Receiver
Model: RX-331S
Modulation: FM/PPM
Intermediate frequency: 455 KHz
Power Supply: DC 4.8~6.0V
Dimensions: L:42 x W:27 x H:16.3mm
Servo
Model: SRM-102Z Heavy duty standard servo
Dimensions: L:39 x W:20 x H:36mm
Speed: 0.2sec. at 6.0V for 60 deg rotation
Torque: 3.3kg cm at 6.0V
INFO: http://www.der-schweighofer.com/web/pro ... prodID=970
Cenik: http://www.serpent.at/cars/zubehoer/Ver ... -SANWA.pdf
CENA: pod 200 €
