Polnilec (12V) Simprop - INTELLI SPEED
OdgovorNapisal/-a nitro-s » 02.11.2005, 23:39
Polnilec INTELLI SPEED
Technische Daten:
Eingangsspannung 10 - 15 V DC (Gleichstrom)
Ausgang 1 bis 14 NiCd/NiMH Zellen-Akkus, 2V bis 12V Bleiakkus,
1 bis 5 Li-Ionen/Li-Polymer Zellen-Akkus
Ladestrom 0,1 bis 7A
Entladestrom 0,1 bis 1A
Entladeschlussspannung einstellbar
Display 2x 16 Zeichen, beleuchtet
Abmessungen ca. 127 x 92 x 30mm
Gewicht ca. 365g
INFO: http://www.simprop.de/Seiten/Modellbau/ ... iSpeed.htm
CENA: 72 €
Link: http://www.der-schweighofer.at/web/prod ... &prodID=10
Prispevkov: 3327
OdgovorNapisal/-a MaNe » 03.11.2005, 11:16
Dober polnilec za tako ceno.
OdgovorNapisal/-a GODFATHER » 03.11.2005, 11:26
Premalo A za praznenje!
Za malo več cca. 20 eur se dobijo boljši polnilci!
OdgovorNapisal/-a Parky » 03.11.2005, 11:54
Men je tale dost hud in ga imam tud doma :D
nput Voltage: 11-15V DC
Battery Types, # of cells: 1-10 Nickel-Cadmium cells (1.2-12.0V NiCd)
1-10 Nickel-Metal Hydride cells (1.2-12.0V NiMH)
1-4 Lithium-lon or Lithium-Polymer cells (3.6-14.8V Li-lon/Li-Po)
Battery capacity range: 100-9900mAh
Fast charge current: 0.1-8.0A (1C max for Li-lon/Po)
Fast charge methods: linear, reflex, impulse and 4-step
Fast charge termination: Peak detection for NiCd and NiMH "constant current / constant voltage" for Li-lon / Li-Po optional thermal cutoff for all battery types
Peak sensitivity: 0-25mV adjustable
Trickle charge current: 0-500mA (n/a for Li-lon / Li-Po)
Discharge current: 0.1-10.0A adjustable
Dishcharge cut-off voltage: 0.1-1.1V per cell NiCd & NiMH 2.5-3.7V per cell Li-lon / Li-Po
Temperature cut-off range: 50-132°F (10-56°C)
Cycle count: one to ten cycles (n/a for Li-lon / Li-Po)
Cycle cooloff delay: 1-30 minutes adjustable
Battery memories: 10
Display type: 8 line, 21-character LCD (168 characters max)
Graphical displays: Graphs charge and discharge voltage curves
Output connectors: banana jacks (two adapter leads included)
Motor break-in: 1.0-8.0V selectable, 1-120 minutes, 10A constant
Case size: 5.5 x 1.8 x 5.9" (140 x 45 x 150 mm)
Weight: 21 oz. (605 g)
Parky
Prispevkov: 349
Pridružen: 10.10.2004, 12:34
Po forumu brska: Bing [Bot] in 10 gostov
