Celice LG Li-Ion 2200 mAh 3,7V
OdgovorNapisal/-a nitro-s » 06.12.2005, 00:29
Baterije - celice LG ICR18650S2 Li-Ion 2200 mAh 3,7V
Capacity: Norminal 2200 mAh, Minimum 2150mAh
Dimensions Diameter: 18.3±0.1 mm (Max 18.4 mm)
Height: 64.8±0.2 mm (Max 65.1 mm)
Weight (Typical) Approx. 44.5 g
Nominal Voltage Average 3.7 V
Internal Impedance ≤ 90 mΩ (with PTC)
Cycle Performance 80% of initial capacity at 300 cycles
Charge: Current = 1075 mA, Voltage = 4.2 V, End Current = 50 mA (CC-CV)
Discharge: Current = 430 mA, End Voltage = 3.0 V
INFO: http://www.lgchem.com/en_products/elect ... ttery.html
Zadnjič spremenil nitro-s, dne 06.12.2005, 00:48, skupaj popravljeno 1 krat.
OdgovorNapisal/-a nitro-s » 06.12.2005, 00:31
Danes sem dobil 4 kom na test (brez oznak - logotipa). :wink:
