Brezžična telemetrija za model letala na vaši komandi
OdgovorNapisal/-a nitro-s » 01.11.2004, 01:23
Brezžična telemetrija za model letala na vaši komandi - Seagull Wireless Telemetry (samo v USA). :lol:
Link: http://www.eagletreesystems.com/Seagull/seagull.html
FDR Specifications
Logged channels: 16
Airspeed from ~9MPH to 290MPH
USB Live Mode for real time bench monitoring
Altitude to 25,000+ feet
Climbrate
4 channel servo positions and glitches
Dual temp to 424 degrees F
Tachometer to 40,000+ RPM
Receiver battery voltage
Electric motor current to 90 AMPS*
Dual Axis G-Force to 38G*
Dual Exhaust Gas Temp to 2000+ degrees F
Cena - Flight System: Seagull Wireless Dashboard with Flight Data Acquisition $369.99
Link: http://www.eagletreesystems.com/Plane/plane.html
Re: Brezžična telemetrija za model letala na vaši komandi
OdgovorNapisal/-a webmar » 02.11.2004, 19:08
nitro-s napisal/-a:Brezžična telemetrija za model letala na vaši komandi - Seagull Wireless Telemetry (samo v USA). :lol:
FDR Specifications
Logged channels: 16
Climbrate
OPROSTI .ampak to dela tudi WEBRA, v EVROPI Prodaja pa po celem svetu.Pa se poceni je .LP
Miran
webmar
Prispevkov: 139
Pridružen: 12.01.2003, 02:14
OdgovorNapisal/-a JureHB » 02.11.2004, 19:23
A to ti zabeleži vse te podatke?
JureHB
Prispevkov: 159
Pridružen: 03.05.2004, 14:11
OdgovorNapisal/-a nitro-s » 02.11.2004, 22:55
Miran res je, da ima nekaj podobnega tudi Webra, samo funkcij ima zelo malo (samo 4) in to samo za letala. :wink:
Webra RDS4 Telemetry System
Das Webra RDS4 Telemetriesystem kann während des Flugbetriebes folgende Daten laufend übertragen:
The Webra RDS4 Telemetry System is capable of constantly transmitting the following data to the pilot while the model is flying:
Motor temperature 0 - 200 °C
Motor speed 100 - 99,000 rpm
Receiver battery voltage 3 - 7 V
Servo travel 0 - 100 %
Dela na 433 MHz :shock: :cry: (na tej frekvenci delajo vsi mogoči brezžični daljinci - avto alarmi, gar. vrata in .....)
Link: http://www.webra-austria.at/electronic. ... IE&lang=EN
Cena: 297 €
Link: http://www.modellbau123.at/product_info ... c7e96f1d1d
OdgovorNapisal/-a webmar » 04.11.2004, 21:18
nitro-s napisal/-a:Miran res je, da ima nekaj podobnega tudi Webra, samo funkcij ima zelo malo (samo 4) in to samo za letala. :wink:
Cena: 297 €
HI Oprosti napacna razlaga za WEBRO.. Kljub tvoji strokovnosti ,napača v vseh pogledih. Specialisti pa naj sami presodijo LP .PS baje je nek vas član dip ing to ze htel kopirati in prijaviti kot svoj izum. LP .
Miran
webmar
Prispevkov: 139
OdgovorNapisal/-a nitro-s » 05.11.2004, 01:57
Miran, kaj je tu napačnega. :shock: :?:
Vse kar tu piše je objavjeno na njihovi uradni strani in si preberi: :!:
Klikni :arrow: http://www.webra-austria.at/electronic. ... IE&lang=DE
Motortemperatur 0 - 200 °C
Drehzahl 100 - 99,000 rpm
Empfänger-Akkuspannung 3 - 7 V
Servoweg 0 - 100 %
Frequenz 433 MHz
Moram pa ti povedati, da se na te reči dobro spoznam in če ti ni kaj jasno ti samo vprašaj, imam izkušnje. :wink:
Miran, imaš napačne informacije. Ta naš član NI dipl. ing. ampak dr. (doktor elek. in rač.) Iztok K. in je telemetrijo hotel sam narediti, ne pa kopirati. Tudi našega IRT merilnega sistema je on avtor. :wink:
Vrni se na Novosti..
