Ena zanimiva zadeva, ki se dobi pri DMT-ju so Tanic LiPo celice!
Posebej selekcionirane in imajo polnilne prikljucke za vsako posamezno celico!!!
Info:
"TANIC TAPS" are designed to allow you to balance the voltages between the cells in your battery pack. You may use them as often as you wish, though necessary maintenance of your battery pack requires you to use TANIC TAPS to balance the pack when voltage fluctuations become greater than .05-.1 volts between any two cells. (i.e. cell 1 3.2, cell 2 3.3, cell l3 3.4 needs balancing, cell1 3.2, cell 2 3.2, cell 3 3.25 does not require it)
There are two methods that you may use to balance your battery pack.
The first method is to plug in the male BEC plug (included) to one of the Female BEC plugs on the battery pack and charge @ a rate not to exceed 1C (Capacity. ex: 2200mAh pack max charge rate 2.2 amps). Your charger must be set to 1 cell (3.7 volts nominal) IF THIS SETTING IS NOT CORRECT, THE CELL/PACK MAY EXPLODE. After the charger is done with that cell remove male BEC plug and plug it into the next cell and charge. Continue until all cells are fully charged.
You are now done balancing your pack. All cells will be at nearly the exact same voltage. There is a period of settling; the last cell charged will have higher voltage for a while but the pack can be used immediately.
The second way to balance your the pack is to charge it as a normal xS pack with the main leads plugged into the charger. Charge the pack until the amperage on the charger starts to drop. At this point, remove from the charger and use the "TANIC TAPS" to top off each cell, again remembering to change the setting on the charger to 1 cell (VERY IMPORTANT). Again, if you do not change the setting, the pack will explode. Using this method will speed up the balancing process, as you don’t have to wait the entire charge time for each cell.
