Motorji - micro 180 za modele 1:24 in 1:18
OdgovorNapisal/-a nitro-s » 03.01.2004, 02:17
Nekaj modelov:
Cene so informativne 8)
PEK1405 Raider Micro Modified 37.00 $
PEK1403 Turbo Coreless Micro Modified 69.99 $ (49,00 $)
PEK1401 Chubby Micro Modified 36.99 $
PEK1400 Wind Micro Modified 24.99 $ (19,90 $)
Orion Elite Motor 55.00 $
Slika Slika
ORI20904 Team Orion Micro Core modified motor 29.00 €
HPI1065 Micro Modified motor (45T) 35.00 €
ORI20901 Team Orion Elite Micro Stock Motor 12.00 €
HPI1060 Micro RS4 motor with plug (FK180SH) 16.00 €
podoben motor je tudi Carson Speedy 24 15.00 €
OdgovorNapisal/-a nitro-s » 04.01.2004, 01:27
Najbolj iskani motor (180) Team Orion Elite Micro Modified za modele 1:18 (Xray M18, HPI Micro RS4). 8)
Slika Slika Slika
Inside the Team Orion Elite Modified:
1 - Flange
2 - Permanent magnet
3 - Housing (magnetic return)
4 - Shaft (2mm)
5 - Winding
6 - Commutator plate
7 - Commutator
9 - Precious metal brushes
10 - Cover
11 - Electrical connection
13 - Sintered sleeve bearing
Elite Modified Technical Data:
Watt: 5
No load Speed: 6.0 Volt 17820 rpm - 7,2 Volt 21384 rpm
Stall Torque: 29.7 mNm
Terminal resistance: 0,325 Ohm
Efficiency: 87%
Magnet: Neodym
Commutator: 9 segments
Brushes: Precious metal
Weight: 42g
Length: 28,9 mm
Diameter: 21mm
Priporoča se regler - ESC z podatki (Flash Micro ESC):
Št. celic : 4 to 8 (4,8 V - 9,6 V)
Tok : 5 A trajno, 25 A peak (2 seconds)
BEC : 5 V, 1 A
Še druga mnenja (180-5W, 300-25W): http://www.team-orion.com/toptalk/showf ... o=&fpart=1
OdgovorNapisal/-a nitro-s » 11.01.2004, 23:17
Tanke priključne žice iz motorja na regler - ESC :lol:
Slika Slika Slika
Test motorjev na stezi v modelih HPI:
http://www.team-orion.ch/news.asp?id=176
OdgovorNapisal/-a mihah » 12.01.2004, 13:16
nitro-s napisal/-a:Tanke priključne žice iz motorja na regler - ESC :lol:
Kaj pa rabiš drugega kot tanke žice za tist amperček al pa dva? ;)
OdgovorNapisal/-a TomyBoy » 15.02.2004, 17:49
Team Orion Elite Micro Modified Motor
Cena 65 EUR :)
http://www.rcshoproal.nl/easyshopmaker/microspeed.html
OdgovorNapisal/-a nitro-s » 08.03.2004, 21:51
Prejšnji teden sem kupil 180 motor Team Orion 20904 Core Micro Modified in sem z njim zelo zadovoljen. :lol:
Cena: 6.000,00 Sit (25 E) 8)
Nekaj osnov o el. motorjih (Timing, Winding, Welding)
Slika Slika Slika
LINK: http://www.teamorion.com/faq/motor3.asp
OdgovorNapisal/-a TITan » 01.05.2004, 23:15
Da daodam še jaz nekaj tukaj zraven (malo stara tema, sam pać).
Speed 300 6v
Specifikacije:
30000 RPM @ 6v (!!!)
30W
Max tok 5A
V 1:24: skoraj nevozen na drugem kot tepihu z pencam in štirimi AA NiMH 1800mAh celicam
Cena: cca. 1500SIT
Dobavliv pri nas. :lol:
Z malo dodatnega timinga, malo večjim pritiskom na krtačkah se da komot ene 35w ven stisent.
TITan
Prispevkov: 116
Pridružen: 12.11.2002, 21:12
