FG 1:5 Elektro
FG 1:5 Elektro
OdgovorNapisal/-a mihah » 13.02.2004, 22:19
OdgovorNapisal/-a TomyBoy » 14.02.2004, 00:35
:shock: :shock: :shock: mrcina.
OdgovorNapisal/-a slonic » 14.02.2004, 10:53
Zeeelo zanimiv :D
slonic
Prispevkov: 154
Pridružen: 03.04.2003, 22:55
Kraj: Sežana
cool
OdgovorNapisal/-a pako » 14.02.2004, 12:25
Avto je prow huuddd sam s temle motorjem pa ne vem ce gre kaj več kot 1:18?? :D
pako
Prispevkov: 177
Pridružen: 26.05.2003, 20:50
Kraj: Sodražica
OdgovorNapisal/-a DobnikarA » 14.02.2004, 15:16
S temle se bi pa še kako dalo z brushless-i eksperimentirat (xx število celic, pa bi stvar kr dobr letela) :lol:
OdgovorNapisal/-a mihah » 14.02.2004, 20:25
Lauterbacher PRO5 Elektro (že kar nekaj let staro...)
http://www.lauterbacher.com/modelle/pro5/pro5.html
OdgovorNapisal/-a mihah » 15.02.2004, 01:50
Pa še nekaj besed firme BK Electronics na temo avtomobilov v tem merilu.
We didn't know which motor and controller combination that was suitable, even after tedious calculations. Then we decided to use the LMT 2250/10 motor and a 3080 controller. With the translation it was an everlasting trial and error. However, we found (we think) an ideal setup for this large scale model.
Good power from the lower speed range up to a fabulous top speed of more than 88 mph. We think more diverse fine work and adjustments, as well as other modifications are possible, which could bring the car to approx. 115 mph, with the number of cells being 30 - 32, having an acceleration of approx. 3 - 4.5 Seconds.
Some technical data :
Manuf. Model: GP - Racing - USA (you can order from us)
Model: Nescar 1 : 4
Total length over all: 125 cm
Total width: 50 cm
Overall height: 30 cm
Motor: 2250/10
Load rpm at 24 Cells: 31250
Load rpm at 30 Cells: 39080
Load rpm at 32 Cells: 41670
Controller: 3080 (Controller and motor could be used
with its own water cooling system.)
Weight: ca. 8.5 kg
Rate at present: 88 mph
Sound: Sound module = V 8 Racing car noise.
If we have any new experiences and/or measurements, we will always correct this page with the latest data.
Of course, we can offer the car as a complete car. This model is sold with three different chassis. If you are interested just send us an email or give us a call.
OdgovorNapisal/-a mihah » 15.02.2004, 01:52
Mogoče še pomoč za tiste "nadležne" milje.
88 mph = 141.622272 km/h
115 mph = 185.07456 km/h
OdgovorNapisal/-a TomyBoy » 15.02.2004, 02:23
Pa kaj si ti nor koliko celic.Kako to pol filaš ? Leti pa da to res ni. To bi bilo lepo enkrat videt. To je nekako tako hitro in še hitrejše od C-ja. :)
OdgovorNapisal/-a mihah » 15.02.2004, 12:11
Nič posebnega glede polnilcev - Graupner Ultra Duo Plus 30, vsi Schulzeji, Orbiti, ...
Doma moraš imeti dober usmernik (30 A), na terenu pa dober 12 V "svinec" >80 Ah.
Glede tega enkrat videt - sem iskal na netu, o nemška kategoriji 1:5 elektro nisem veliko našel... pri nas pa kej več kot 1:10 na 6 celic BK avtov ne boš našel (ali mogoče pač?!:shock:)
Pridi na kako tekmo ali trening čolnov. Letos bom bil spet zelo aktiven v Hidro 3 klasi (za SP na Poljskem). To ma 20 akujev in gre tudi že kar pestro (nič kaj dosti manj kot 1:8 C)
