Uspešna inštalacija zunanje vrtečega BK motorja v Emaxxa:
http://www.radiocontrolzone.com/forums/ ... genumber=2
hi, there, here´s another pic of one of my latest projects, this maxx is very light (as you might see ) and it will be driven by a single lrk motor setup, with 5 times the power than a "normal" bl motor !!!
the whole car is beefed up with steel, hardened aluminium and titan!
the cg is greatly lowered by a full 2.5 cm !!! (1 inch !!) that really is good extra benefit, the motor is lying on my table, just waiting for the time to be built in, but i do not have the time till the week, next weekend it WILL be inserted, as i have a week off (not working, yes!!)
It´s ready !!
the motor fits perfectly, the power is really awesome, the tranny is never missed, these Construction really makes it, i can not change the gearing that easy, but this is not a must have, due to the fact that the car is running near to the 60 Mph !!
(so why upgrade !! )
The lowered cg is really good for the side to side movement, I´m now plannin g on building a 3 shock for front and rear each !! (like the tuning system in the rccaraction (latest issue))
but way much more down with the cg !! (directly on the upper arm or anything like this !!)
The Motor only needs this see thru case, because the outer housing is rotating too, there is a way for the small rocks in the outer world !!
these are the Datas:
600 -1000 W at a max of 70 A and rpm per Volt is 1200 (as i do not use any tranny, i do not need these High rpm-low torque BL from Hacker or lehner.
This is a torcman 350/20 10 poles with 10 windings (only driveable with a ESC that has degrees setting (from 15 to 30 ° would be good, I´m still comparing the tech Datas, haven´t figured out anything yet)
This motor has the twice the torque than 2 pieces of 17x2 brushed motors on 12 cells, but this thing was only running with 6 cells at the test !! (my esc was not able to pull out more, due to the degrees setting)
really awesome and cheap !! (as akit, yes you can buy these motors as a kit and wind your own one !! and as a ready motor (the kit is around 100 USD (only the wire goes extra) and the ready Motor is around 160 USD (for this motor type, others are cheaper or cost more (up to 700USD and an output of 3000 W !!! (no mistake !!) and a weight of 1.4 kg (a totally equipped 10th sedan !!)
really good for a MT 5th scale project . . .
