XRAY T2R
XRAY T2R
OdgovorNapisal/-a JC Borcy » 20.07.2006, 09:31
Spet ena novost pri xray-u. :lol: 1:10 elektro T2R
Model bo mogoče kupiti pri MANTUA-MODEL
The T2R is a Raycer concept of the T2, which means the highest performance for an affordable price = the best price/value combo
The T2R is aimed for customers who do not need to shave the hundreds of a second and look for the highest performance in the market but still want to race at the club level a car that has the highest quality, is easy to build and maintain and is available for an affordable price.
All parts are compatible, so the driver who will start with an T2R can anytime upgrade to the high-specs T2 easily. If you have some friends who look for high performance, best quality and good price, then the T2R is a perfect car for them.
XRAY has made a name for themselves in a time frame that other should envy. You say that word and people think quality and performance. The quality has always come at a price and for the most part XRAY is usually at the top of the budget food chain. As touring cars creep closer and closer to the $500 range you can see a subtle decline in people entering the segment. Where the FTTC3 used to allow a budgeted entry point that didn’t sacrifice performance the options for the budget minded have shrunk to non-existent. Leave it to XRAY to fill that void. The past “budget version” of the FK. 05 was they Raycer. That car never really took off, but the newest version looks to be a winner in everyway. XRAY is bringing high-end performance in reach of more with the latest version of the T2…the T2R.
We haven't gotten our kit yet to say what materials are different but from the looks of it there isn't much that's not the same, unlike the previous Raycer that had molded parts instead of the machined aluminum.
“With the world wide success of the T2, my best touring car design to date, I wanted to release a platform that would allow everyone to enjoy the design and performance benefits of the T2 no matter what their racing needs and budget are.” -Juraj Hudy
T2R features & specs:
• Built on the successful award-winning and racing dominating T2 platform
• Expected street price 199€ including VAT
• XRAY Multi-Flex Technology™ (XRAY patent): fully adjustable chassis and top deck torsion and flex (alu stands available optionally)
• XRAY Quick Roll-Centers™ (XRAY innovation) – 4 quick roll center adjustment, front and rear
• 3mm thick front and rear FRP shock towers featuring the XRAY Quick Roll-Centers™
• Lightweight, strong, and durable suspension shared with the T2
• Rebuildable CVD driveshafts made from special world-renowned, Hudy Spring Steel™. The world’s thinnest yet most durable drive shafts are hand ground for maximum precision.
• Ultra-lightweight front and rear split bulkheads are CNC-machined from Swiss 7075 T6 aluminum, allowing super-easy diff and layshaft access
• Narrow 2.5mm FRP chassis with batteries and all electronics centrally positioned
• Special lightweight aircraft aluminum middle layshaft supporting large 20T central pulleys
• Front lower and upper composite bumper made from special composite to withstand hard impacts
• Compact front foam bumper made from lightweight, high-resilience foam
• Thick 6mm body posts
• 7075 T6 aluminum rear brace for maximum rear bulkhead rigidity & strength
• Lower suspension alu holders with three different roll center positions
• Small yet robust rear uprights with built-in 1° outboard toe-in
• Easily-adjustable in-board toe-in using included shims
• Easily adjustable wheel offset using optional shims
• New hard composite easy-to-mount wheel hubs
• XRAY 4-step externally adjustable shocks allow easy and quick adjustment
• Standard non-adjustable shock pistons for beginners available in the kit too
• Shortened shock rods are specially hardened for maximum strength
• Shock absorber foam inserts for improved shock rebound
• Hardened 84T spur gear
• Small 4° caster C-blocks from special composite material
• T2 small yet robust steering blocks made from special composite material, featuring two Ackermann positions
Other Specifications:
• Pure racing design, long life, ultra-stiff chassis
• Very easy assembly/disassembly and maintenance
• Fully independent, fully-adjustable suspension
• Highly-efficient 2-belt, 4WD system with ultra-low CG
• High-performance Kevlar-reinforced drive belts
• Adjustable Ackermann settings
• Centrally-positioned servo saver
• Composite battery backstops prevent battery movement on chassis
• World's most efficient drivetrain with 1.7 internal ratio featured at T2 platform
• Super-efficient 20T middle shaft pulley enables better belt wrapping and improved drivetrain efficiency
• Externally-adjustable front and rear differential made from special high strength composite. Aluminum collar to prevent the diff outdrives from spreading.
• Differential features carbide balls and carbide axial thrustbearing for maximum life and highest performance
• Belt tensioning adjustment in both front and rear bulkheads
• Adjustable Hudy Spring Steel™ turnbuckles (steering, front & rear upper links)
• Complete set of high-speed blue-sealed ball-bearings, degreased, lightly oiled for maximum efficiency, individually controlled, selected and inspected
Adjustment Possibilities:
• Fully-adjustable front and rear suspension geometry: caster, camber, toe, anti-dive, anti-squat, ride height, downstops, track-width, roll center, wheelbase
• XRAY Multi-Flex Technology™ (XRAY patent): Fully-adjustable chassis and top deck torsion and flex
• Externally adjustable front and rear ball differential
• Adjustable bulkheads for belt tension control
• Multiple upper and lower shock mounting locations for front and rear
• Externally-adjustable racing shocks (4-step)
• Pre-drilled chassis locations for optional chassis weights
• Adjustable steering Ackermann through servo saver stand position
• Adjustable front and rear anti-roll bars (optional)
Re: XRAY T2R
OdgovorNapisal/-a MescaN » 20.07.2006, 11:42
JC Borcy napisal/-a:• Expected street price 199€ including VAT
Ugodno ...
No, pa se nekaj slik ...
http://www.rcinfos.com/2006/2006_07_19_xray_t2r_pictures.php
Lep pozdrav, Matej
MescaN
Prispevkov: 41
Pridružen: 07.12.2002, 01:07
Kraj: Trebnje
OdgovorNapisal/-a Scythe » 21.07.2006, 16:23
hm.. eno vprasanje .. meni glih ne leži ang .. pa me zanima ce ste kaj brali ce je avto karbonski pa če so vsi deli enaki oz. se ga da nadgraditi z difi.. ki so v t2
in vse te stvari .. HVALA
OdgovorNapisal/-a Sajo » 24.07.2006, 09:00
malifant napisal/-a:hm.. eno vprasanje .. meni glih ne leži ang .. pa me zanima ce ste kaj brali ce je avto karbonski pa če so vsi deli enaki oz. se ga da nadgraditi z difi.. ki so v t2
Avto ni karbonski, se ga pa da nadgradit. Deli naj bi bili vsi enaki, razlika je le v materialih. Diff je drugačen, zdi se mi da je v T2 aluminijst, v T2R pa plastičen, ne me pa držat za besedo, ker sem tisti del samo na hitro preletel.
Lp, Luka S.
Performance through evolution
Sajo
Prispevkov: 46
Pridružen: 16.12.2002, 18:48
OdgovorNapisal/-a Scythe » 30.07.2006, 18:23
Je model že možno kupit !!??
OdgovorNapisal/-a MANTUA » 30.08.2006, 16:20
V preteklih dneh sem dobil precej vprašanj o dobavljivosti XRAY-a T2R, ki bo verjetno postal najbolj priljubljen tekmovalni model za začetnike in srednje zahtevne tekmovalce, torej odlična izbira za dirkanje na LRP tekmovanjih.
Prva majhna pošiljka modelov je že na voljo. Uspelo mi je dobiti samo en model, ki bo v trgovini predvidoma v petek (1.9.2006). Tisti ki si ga najbolj želi, ga lahko rezervira, saj model verjetno ne bo prišel na polico. Večjo pošiljko pa pričakujem v drugi polovici Septembra. Takrat bodo na voljo tudi "LRP challenge" kompleti z motorji in regulatorji LRP.
Kot sem že omenil počasi sestavljam zalogo rezervnih delov za modele XRAY T2 in T2R (večina bistvenih delov je enakih). S pomočjo tekmovalcev bom poskrbel, da bodo deli dosegljivi tudi na tekmovanjih.
MANTUA
Prispevkov: 411
Pridružen: 06.01.2003, 12:33
OdgovorNapisal/-a Scythe » 02.09.2006, 07:16
Avto sem imel v roki že v Četrtek ..
OdgovorNapisal/-a MANTUA » 04.09.2006, 20:08
Modeli so na zalogi. Večina rezrvnih delov tudi, kmalu pa bo dobavljiv tudi model z "LRP Challenge" paketom.
MANTUA
Prispevkov: 411
